Methor or property for tools>>options
Just want to change my labVIEW options (tools>>options) through a method or property node and I can't figure where it is...
Message 1 of 18
(3,950 Views)
Exactly what option do you wish to change?
Message 2 of 18
(3,935 Views)
Does it matter ? Can't I change any of those LabVIEW options programmatically ?
Let say for example Automatique routing or Automatic cabling.
There's a property node for automatic routing of wires but you have to go under tools>>options if you want your modification to be saved...
Message 3 of 18
(3,921 Views)
You could just modify the labview.ini file.
Message 4 of 18
(3,901 Views)
I could... if not better solution...
Message 5 of 18
(3,894 Views)
Well, thats exactly what the option dialog does. What could be better? 😄
(not sure if there are permission issues...)
Message 6 of 18
(3,888 Views)
Well, I must be lazy... if something else, like a propety node, can manage the labview.ini file... 😄
Message 7 of 18
(3,876 Views)
Message 8 of 18
(3,869 Views)
Yep, I know... already done...
But your credo isn't "Do more with less code and in less time " ? 😄 So disappointed... 😉
Message 9 of 18
(3,860 Views)
How often do you need to change the values in your LabVIEW.ini file that you need to programmatically change them?
Message 10 of 18
(3,848 Views)
