Metrics on Labview VIs
Does anyone have a VI or utility that will collect lines of code equivalents
for Labview VIs? Or any other similar SW metric for measuring complexity
of LV code?
(3,334 Views)
> of LV code?
You do not say what version you have.
There is a tool in the Professional Dev System for lv5.1
that does VI metrics. It measures quite a few parameters of your VIS
If you have PDS Version 5.1 look under the Project menu and select
VI Metrics.
If not you may want to consider upgrading or contacting NI sales.
Kevin Kent
(3,333 Views)
