Micro-Epsilon bulid own development environment
hey,
i build my own development environment with the micro epsilon contents to scan profiles.
I get a connection signal but no values. In addition, I would like to trigger the laser with the encoder. does anyone have any experience with it?
(2,524 Views)
hey,
i build my own development environment with the micro epsilon contents to scan profiles. I get a connection Laser but i get no values. In addition, I would like to trigger the laser with the encoder.
(2,520 Views)
Dear  Akbaba66x,
As I wanted to run your code it requires control named TypefedProfielConfig.ctl, Can you please attach the project as a whole?
Best,
anasei.
(2,432 Views)
Hi anasei,
Right click the control and "disconnect from typedef"…
(2,419 Views)
Dear ,
It worked. However there are still missing custom vi's in the code that needs to be attached.
Best,
anasei.
(2,408 Views)
