Micro-Nuggets !!! ~~~~ Post 'em if you got 'em
@Steve Chandler wrote:
Hey, maybe a reuse VI that contains the Here.vi and the comment with a scrollbar below it. Set that VI to place contents.
Nice if you only want one comment....or you want to search though every Here-x.vi created from Here.vit in the heirarchy (Bloats vi.llb too)
Message 101 of 368
(2,604 Views)
Not a VIT. Just a VI in the reuse pallet set to place it's contents. It's contents contain Here.vi and a string constant. That way when you drop the container VI it places those two things. I edited my previous post and added a snippet.
LabVIEW 2012
Message 102 of 368
(2,602 Views)
Ive never used that feature.  can you attach the vi (I'm off to the LabVIEW Help file)
Message 103 of 368
(2,600 Views)
I only know how to do this using VIPM so that wouldn't work since you are behind that curtain. Here is a post describing how to do it manually. I know that this is how the math constants work. They are just VIs that place their block diagram contents when dropped. The block diagram just has a numeric constant with the value set to pi or whatever. (Well some of them work that way, I am not sure if they all do)
LabVIEW 2012
Message 104 of 368
(2,595 Views)
Fair enough- So, with VIMP and Odd wires, I am curious to know if I can create that vi and have no effect on the heirarchy view-  If so, I can "ignore the man behind the curtain" and be awarded a brain.
Message 105 of 368
(2,583 Views)
It will not have any effect on the hierarchy view. It will place a string constant and your Here.vi on your bd just as if you had placed them yourself. The weird wires thing is something you can obviously ignore. I just did that manually for effect. If you look for Darrens Nuggets he wrote one on placing VI contents. I'm on my phone now so can't provide a link. I might take back the part about how math constants are just VIs that work like this. I know the string constants do (linefeeds, spsce constant, tab constant) but I cannot verify that the numerics work the same. I imagine they would.
LabVIEW 2012
Message 106 of 368
(2,593 Views)
Bows~~~~Dude....Awesome   RTFM, RTFM, RTFM. I should take my own adviceSmiley Embarassed
Message 107 of 368
(2,588 Views)
Can Micro-nuggets simply point to other nuggets? The "Place VI Contents" (formerly known as "Merge VIs") is an awsome one, that many people aren't aware of.
Darren documented this here: http://forums.ni.com/t5/LabVIEW/Darren-s-Weekly-Nugget-11-23-2009/m-p/1028104
Message 108 of 368
(2,478 Views)
There ain't no rules!
Richard
Message 109 of 368
(2,450 Views)
LabVIEW micro-nugget: Recusively strip path multiple times using Build Path
http://forums.ni.com/t5/LabVIEW/Strip-path-multiple-times/m-p/1408296#M547386
Message 110 of 368
(2,373 Views)
