Micro-Nuggets !!! ~~~~ Post 'em if you got 'em
Ever had a huge Enum to populate which might change occasionally? Have a text file with all the stuff you need? Great! Just populate the Enum using the []Strings property. ... Not so fast. An Enum must be defined before run time, or shall we say, Open time. Here's how to do it:
Create a VI that opens the VI containing the Enum using Server, then populate []Strings using references.
Richard
Message 21 of 368
(9,073 Views)
When a LabVIEW "switch" control has its Mechanical Action set to Switch When Released, you'll notice that it stops half-way as you hold it in. These transitional states can be read and used to fire code by simply reading the boolean text programmatically. Optionally, I am also taking advantage of four different colors that can be applied to the switch as it changes state.
Richard
Message 22 of 368
(8,973 Views)
This question reminded me of a little Micro-Nugget regarding strain gauge measurements. If you use the Bridge Offset Nulling VI, you can use a Property Node to view the values of the on-board potentiometers after the calibration has taken place. What value does that have? Write these values to a file (append) and, over time, view the trending of your offset. I have over two years of offset nulling data which I have used for things like finding increasing side loads on the sensor, and improper installation.
Richard
Message 23 of 368
(8,883 Views)
Nice one BA.  Another reason to monitor this is that one of the first signs of permanent physical damage to a strain gauge is a change in offset.
Message 24 of 368
(8,874 Views)
Not sure if it was somwhere or not, any way, I using it time to time:
Andrey.
Message 25 of 368
(8,866 Views)
That's pretty cool.  The same feature for coerced numerics would be nice.
Jim
LV 2020
Message 26 of 368
(8,856 Views)
That can be done with Type Conversion RCF PlugIn
But String to Path / Path to String conversion is "embedded" LabVIEW feature.
Andrey.
Message 27 of 368
(8,844 Views)
Turn your TypeDefs into OOP Classes easily with this Right Mouse Button feature in Project...
Now get started with OOP by creating Accessors!
Good luck, have fun.
Richard
Message 28 of 368
(8,693 Views)
Communicating between two loops seems to be coming up a lot lately, so I thought I'd post my example.
Download all three files in one folder. Run the VI named Communicating Between Loops.
p.s. "Bad" ways, as well as "good" ways to pass data are shown; however, they all have their place, except the Global. Smiley Tongue
I strongly recommend the Queue and or Notifier.
Richard
Message 29 of 368
(8,324 Views)
Hi Broken Arrow,
Good work on the communicating between loops vi. As you say this is always asked on here so needs covering. One thing i would suggest for your examples is perhaps a small write up next to each example explaining when and when not to use them. As you say there and good ideas and bad ideas on there, maybe an idea to highlight the Dont's. Just a thought, Good job Smiley Happy
Lucither
"Everything should be made as simple as possible but no simpler"
Message 30 of 368
(8,262 Views)
