Microsoft Access conection
Hello;
I am working with mocrosoft access to save my data from the LabVIEW test.
From my development PC all is well, I can read Write and delete data from Access as I would expect.
when I build the .exe and move it to the lab, the VI gets hung up on a connection error.  with a path that is not on the lab PC or my developemnt pc.
The long and short of the erroe message is there is a problem with my connection string.  That string is more or less right out of the LabVIEW example. "Provider=Microsoft.ACE.OLEDB.12.0;Persist Security Info=False;Data Source=%s\\"
The rest of the string is the access database name.
The error is an ADO error
ADODB.Connection:provider can not be found
The lab PC does not have Access or LabView installed...............
Any help is appreaciated.
Do I need access on the target PC?  Or is there something I did incorrectly when I built the .exe?
Michael C. Nedrow
(4,683 Views)
Accepted by topic author mcnedrow
You don't need Access installed and I can't tell if you've done anything wrong, but I've faced the same problem and solved it by installing the Microsoft Access Database Engine 2010 Redistributable from - http://www.microsoft.com/en-us/download/details.aspx?id=13255
Jim
(4,669 Views)
THANK YOU.....
That did the trick......working like a charm now.
Michael C. Nedrow
(4,664 Views)
