Microsoft Chart Control
I am trying to use the ActiveX object library for Microsoft Chart
Control 6.0,
located in the file MSChrt20.ocx.
I am doing this in LabVIEW and not in VB.
The problem is that I do not have VB 6.0 at all, but have managed to
find
the file MSChrt20.ocx on the net. After registering this component on my
NT-PC,
I am able to hook on to the MS Chart control in a container, but it is
not working.
So the question is, what is it that I need in addition to the
MSChrt20.ocx-file,
to make this work ?? Does MSChrt20.ocx need some dll's or some other
OCX's or what ?
Any LabVIEW hackers around that been into this ?
Please reply directly to me also.
Martin
(4,067 Views)
Martin,
You probably donot have a design time license for the chart ocx control and
hence you do not have access to it's properties and methods from a designer
environment. There is a very good(powerful) straight forward ActiveX graphing
control called TeeChart, which Borland Delphi programmers have been using
for years. I highly reccommend it. It is not free, however it is not too
expensive, and I'm sure they have free trial versions available.
Dan Sox
(4,067 Views)
Simply install Word or Excel, it's easier ! 🙂
Martin Plassen a écrit dans le message :
39292C65.4DDB018E@chem.sintef.no...
> Control 6.0,
> find
> NT-PC,
> not working.
> MSChrt20.ocx-file,
> OCX's or what ?
> Martin
(4,067 Views)
