Microsoft Speech and labview
i am Khaled ,Mechatronic engineering ... i don't know how to integrate  Microsoft Speech in windows Vista with the LabVIEW for example i want to use  my voice to have output from LabVIEW and from searches i found that  Microsoft Speech is the best ad easiest solution
khaledyr
(3,997 Views)
Where did you search and what did you search for? A search on the NI site for "microsoft speech" yields many results:
http://search.ni.com/nisearch/app/main/p/bot/no/ap/global/lang/en/pg/1/ps/10/q/microsoft%20speech/
(3,987 Views)
yes i know that there are many results for the search but there is no examples about how to turn on and off motor or led by my voice using speech recognition and LabVIEW like the vedio in this link
http://www.ni.com/swf/flv/labview/us/vista/vr/
Khaledyr
(3,961 Views)
There are also examples for speech recognition:
http://search.ni.com/nisearch/app/main/p/bot/no/ap/global/lang/en/pg/1/q/labview%20speech%20recognit...
You won't find one specific to turning on/off a motor, but the examples can be used to determine what you need to do.  For instance, to turn the motor on/off you need some hardware. So you can write the VI to control the hardware to turn it on/off, and use speech recognition to call this VI.
(3,954 Views)
This example goes the other direction (it generates speech from text, rather than generating text from speech), but it shows how you can call speech functions in the Microsoft .NET 3.0 environment from LabView.
(3,943 Views)
