05-30-2013 12:00 PM - edited 05-30-2013 12:03 PM
Hi Guys,
Im new to LabeVIEW but a colleague and I are working on an automated monitoring project with our company.
We have the Microsoft office report package however I am looking for a few simple examples or tutorials explaining their use.
I seen that the below 2 examples were available at one point but now seem to be dead.
Can anyone help?
Seamus
05-31-2013
10:36 AM
- last edited on
04-11-2025
12:25 PM
by
Content Cleaner
Hi Seamus,
Welcome to the National Instruments discussion forums!
I have found a number of resources which may be of use to you as a starting point:
Creating a Report in Microsoft Excel Using the LabVIEW Report Generation Toolkit: Introduction https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x3gcCAA&l=en-US
With regards to the two examples you specify, I have attached a ZIP file containing the entire 'office' folder.
Please let me know if you require these for older LabVIEW versions etc.
05-31-2013 11:38 AM
The Report Generation Toolkit has improved a lot by the addition of Report Classes. I originally "inherited" some code in LabVIEW 7.0 trying to read and write Excel spreadsheets -- it wasn't pretty, nor easy. I've recently recoded this in LabVIEW 2012 -- not only is it much cleaner and more logical code, it runs much faster, and you can do most of what you want/need without delving into ActiveX.
What kind of Report are you doing? I recently wrote a VI to analyze some data, and created an HTML report (mainly because it was so easy to do, and could easily be read without needing Office). Here's how it works:
All of the inputs are strings of text. If you need to write numeric data, you can use the Format As String functions to make the line for you.
Bob Schor
06-04-2013 02:11 AM
Hi Chris,
thanks fot the help. I will work through these examplea nd hopefully they will have what I need.
one other thing I was hoping you might be able to help me with is hte following:
we are using LabVIEW 2010. a former Collogue created quite an extensive LabVIEW program a few years ago when we had labVIEW 2009.
from looking through his program there are some elements of it that would be very useful to our project.
is there any way we can convert over some of his VI's to 2010
Seamus
06-04-2013
02:16 AM
- last edited on
04-11-2025
12:26 PM
by
Content Cleaner
Hi Seamus,
You can simply open older version VIs in later versions of LabVIEW (with some limitations on 'bigger' version differences):
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YSO4CAO&l=en-US
As you are only going forward by one version you should see no issues in opening and using the VIs.
It is also possible to save VIs in an older version of LabVIEW:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGiHCAW&l=en-US
06-04-2013 02:17 AM
HI Bob,
thanks for the info. im not sure the HTML will work in this case.
It might work for some of the more simplier items we require but we have alot of data to log and we want to be able to generate graphs and run some stats etc. so perhaps excel is the better option?
Again I am new to this so I'm not sure how to best approach it, although the HTML option does sound relatively simple.
Seamus
06-04-2013 05:15 AM
Hi Bob,
I am Seamus' colleague.
The report we are looking to create takes information from a 1D array in the VI and inserts it into an Excel spreadsheet.
The VI takes measurements every 15 minutes and displays it in the array. What we are hoping to do is simply insert the array of measurements taken every 15 minutes
into an excel spreadsheet and to also timestamp each measurement.
Thank you for assistance.
Kieran
06-04-2013 11:08 AM
Hi Chris,
I am Seamus's work colleauge. We could not open the VIs in Labview 2010, I would appreciate it if you could create them for Labview 2010.
What we are trying to achieve is to log a DC voltage every 15 minutes in an excel file format.
We are currently taking 4 individual DC measurements in an array on the front panel of a VI. We would like to know what is the simplest way to contiuously log these measurements for the duration of a test period?
Kieran
06-06-2013 05:33 AM
Hi Kieran,
Please accept my apologies for the delayed response.
I Have converted the llb files into a earlier version and you should now be able to open them.
Please let me know if you have any difficulties.
06-06-2013 10:54 AM
Hi Chris,
Thanks for your response and for transferring the VIs into 2010.
I can give you an overview to our problem
1: We wish to create a file path in Excel
2. We then wish to log data/ DC voltage measurements every 5 mins or so.
The excel file will have 2 columns, a column for the date and time of the measurement and the 2nd column will be for the value of the measurement.
3. Each time a measurement is taken, the time it was taken and the measurement value will be logged in the file, so basically we will have a list of time stamps and corresponding measurements..
4 The VI will continue to log the measurements until it is stopped and all the measurements will be saved in the designated excel file.
Thanks again,
Kieran
