Mightex camera not identified by max or Imaq usb enumerate camera vi
Hi all,
I am using Mightex S-Series Ultra-Compact USB2.0 camera, I am finding it difficult to identify the camera in MAX or with IMAQ usb enumerate camera vi, I do have loaded the drivers but still couldnt get the camera working , please let me know if there is anything else I need to upload.
Ankit Gupta
Message 1 of 12
(5,063 Views)
Here is a USB Camera Troubleshooting Document, have a look at it.
Christian
Message 2 of 12
(5,052 Views)
I went throught that troubleshooting document, I installed all the drivers including directshow drivers provided by the vendor. I am able to use there program, but
I cant communicate the camera using Labview IMAQ USB vi, I have the latest version of Vision system and I am running Labview 2012 but still I cant grab the image using labview.
- ankit
Message 3 of 12
(5,040 Views)
When using the latest version of LabVIEW and Vision Acquisition Software the USB camera support (via DirectShow) is included with IMAQdx.
Did you try to run a simple IMAQdx Snap Example? Do you even see it in MAX now?
Christian
Message 4 of 12
(5,037 Views)
I dont see it in MAX, I tried to run IMAQ USB enumerate camera.vi it only showed " integrated camera (webcam of my Laptop) in the list.
- Ankit
Message 5 of 12
(5,032 Views)
If you don't see it in MAX it is very unlikely that IMAQdx recognizes the camera.
You could try to use MS AMCap which could connect to the camera via DirectShow. If this doesn't work either you should contact the vendor.
Christian
Message 6 of 12
(5,029 Views)
I am able to use MS AmCap program, but I cant use IMAQ usb vi's.
Message 7 of 12
(5,020 Views)
Hi AnkitG,
Sorry to hear that you are having problems with your camera. We have recently seen several other instances of Mightex's cameras causing issues when trying to interface with it through IMAQdx, and have been in touch with Mightex regarding these issues. We suspect that the issues all come from differences in the way NI and Mightex handle DirectShow compliance. I'll make sure to communicate this issue to them as well, and I'll let you know what we find.
Message 8 of 12
(5,006 Views)
I'm having the same problem with my Mightex camera.  Has there been any progress or solution to this problem?
Kathryn
Message 9 of 12
(4,815 Views)
Kathryn
Unfortunaltly I have to return it and get other camera which works just perfect for me.
Message 10 of 12
(4,812 Views)
