Migrating applications to Chinese version of windows?
So I have written a couple applications that are used at our US locations to control hardware via GPIB. We now have locations in Asia and I need these applications to work over that side of the pond. Just looking for feedback or people with experiance to alert me of any common problems. My big concern is date / time stamps of my test files. The software is written in LV2010. I will have so co-workers attempting the install later in the week but I don't have access to a Chinese version of windows to see if there are any differences.
PS - GO ALONSO!!!
Kind Regards,
-Chris
(2,747 Views)
F1_Fan,
You should not have trouble installing LV2010 on non-English windows.  If you do have specific problems please feel free to create a new post and we will be happy to help you out.
Sam K
(2,726 Views)
Accepted by topic author F1_Fan
Just curious:  Why the concern over timestamps?  Is it because you are formating as strings in "system format", which will obviosuly be different in China?  If so, you might want to change the code to stick with one specific hard-coded format?
Otherwise, I don't see a problem installing and running it on a Chinese windows PC.
http://www.medicollector.com
(2,721 Views)
I had a couple VI's that used system format; which I now changed. I needed a uniform time-stamp because the data generated is later imported into our QA system which is setup for a very specific format the parser likes.
Thanks!
(2,704 Views)
