Min/Max for computing damping
Accepted by topic author glskinner84
Here are two ways to do it without using a loop.  One uses In Range & Coerce to get a boolean array of peaks within the desired range. The other uses Threshold 1D Array on a reversed array.
Note: If you choose one of these methods, you will need to extract the same subset of the Locations array.
Lynn
Message 11 of 16
(2,023 Views)
Well, it wasn't for a lack of trying...I looked at this for 10 hours today...I guess I need more sleep.Thank you Lynn.
Lynn, why would I need the location if I have the index(amplitude)? My time values don't really matter to me.
Message 12 of 16
(2,005 Views)
All I'm really looking for is the index in which the decay begins...I get then add 5 to this and get my 6th amplitude value in the decay.
Message 13 of 16
(1,990 Views)
If you were to fit the data to an exponential as I mentioned earlier, then you would need both amplitudes and locations. For your ratio method you do not need the locations.
Lynn
Message 14 of 16
(1,946 Views)
 I think I will try both to get a comparison. The locations tie into the 'X' input on the exponential fit.vi, correct?
Message 15 of 16
(1,935 Views)
Yes.
Message 16 of 16
(1,928 Views)
