Mini-Nugget Save time wiring shift registers
Occationally we find that we have to add a new case to our code and wire up a bunch of shift registers as shown below.
This technique save wear and tear on our wrists.
Start by squishing
Then wire!
Ben
Message Edited by Ben on 04-16-2008 09:15 AM
Message 1 of 40
(8,744 Views)
Ben,
Nice idea. Remember to turn off Auto Grow for the structure before squishing.
I find that I often have a case with most of the connections wired through and very little code (Idle or Error for example). Duplicating and modifying that case may be a time saver also.
Lynn
Message 2 of 40
(8,731 Views)
Wouldn't the Tunnel Wiring Wizard do this for you?
Message 3 of 40
(8,729 Views)
How come when I try to open this, it just asks to save changes, then closes itself.  I can't get it to open.  (I'm using LV 8.5)
Message 4 of 40
(8,701 Views)
Wow, great tool, thanks for showing smercurio.
I think this will help if you have more than one new case, if it is only one it doesn´t help.
Mike
Message Edited by MikeS81 on 04-16-2008 05:31 PM
Message 5 of 40
(8,694 Views)
Hmmm... Not sure, as I don't have 8.5. I was able to open in 8.2 and resave it. Try the 8.2 version that's attached.
Message 6 of 40
(8,684 Views)
Hi Ravens,
as far as i see it, you need one more vi in memory to see it.
Mike
Message 7 of 40
(8,681 Views)
Yes, that has been around for a long time and is very useful. I wouldn't be surprised if NI included this functionality in some future version of LabVIEW.
Ben, personally, I much prefer collecting all the SR values into a cluster and then bundling and unbundling by name. That way you have a single SR and the code is cleaner.
___________________
Try to take over the world!
Message 8 of 40
(8,660 Views)
Good mini-nugget Ben. 🙂
I like it.  I also do like tst with the cluster.  But it does happen that a client wants additional features which then require additional clusters and shift registers..  That may mean lots of wiring.  🙂
Message 9 of 40
(8,646 Views)
Mike has the answer.  If no other VI is in memory, neither the 8.0 or 8.2 version will open.  If a VI is open in memory, then they both will open.
This looks like it would be a useful tool.  I'll have to try it out soon.
Message 10 of 40
(8,636 Views)
