Minimize and Maximize Window Applications
If you have a windows application running minimized, is it possible to call it using LabView?  An example of this would be if I had a home security program running minimized can I call it in LabView to maximize it?  I know I can't control this security program using LabView but I would like to be able to minimize and maximize it with LabView.
(6,245 Views)
Here are a set of VI's that you can put into your user.llb. These VI's interact with windows in particaulr there are a couple of VI's for Minimizing and maximizing. All you have to do is input the name that shows in the title bar of any window. Enjoy
Joe.
"NOTHING IS EVER EASY"
(6,236 Views)
can i get the 64 bit library file instead 32 bit
(2,949 Views)
