Minimized window refresh graphic problems
If I have a .vi running with a Waveform Graph in a minimized window, after restoring the window the graphics they appear overlapped.
The existent graph in the moment to minimize is frozen and new lines of graphics appear from the origin mixing with the previous ones.
Some solution for this?
Tnx in advance.
(2,822 Views)
Take a look at this thread...
http://forums.ni.com/ni/board/message?board.id=170&message.id=31565#M31565
I cannot simulate your problem But it may be the same event structure bug discussed in the above thread. Post an example if you can
Good Luck!
Mache
(2,818 Views)
Thank you to dedicate your time to me.
It is very interesting the Property "Defer Front Panel Update" that you comment me.
I will prove this and I will tell you that it happened.
Greeting and thank you.
(2,801 Views)
