Minimum network speed for Fieldpoint
Which is officially the minimum network speed (in Kbit/s) required to communicate with a Fieldpoint? They can operate at 100 and 10 Mbit but that's an ideal maximum, i need to know the minimum recommended for proper working.
I need an estimate of required speed for reading/writing channels (i guess this depends on number and rate of channels), and for programming a RT fieldpoint with LabVIEW.
(3,386 Views)
You can find all the useful informations about Update Rate of a FieldPoint Ethernet Network Controller at this link:
http://digital.ni.com/public.nsf/allkb/24FB518E1D24674686256DD7000C1EFA?OpenDocument
Regarding the minimum possible speed network to comunicate  to FP, it's depends on timeout parameter you set in the target: obviously a low-speed network could  generate some comunication  problems.
Bye
Riccardo
(3,329 Views)
