Minimum requirements of LV standalone executables
I want to locate some LabVIEW created executables in an industrial PC, but I am a bit lost with the minimum requirements I will need to make them run propperly. Is there a way to calculate them or any reference about the issue?
Thank you in advance
(2,632 Views)
In general you will have the same requirements as the LabVIEW Runtime Engine Version you are developing with.
Any drivers you are using (DAQmx, VISA, other) might have different requirements.
Christian
(2,607 Views)
I guess the minimum is a stripped runtime install, thus being able to run that is the minimum. Computer wise it's not very taxing, and most all industrial pc's should be able to run it.
I've recently installed LB8.2 RTE on a tablet/embedded system with a 1ghz cpu and 512 mb memory (if memory serves). That worked well.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(2,581 Views)
