Mircosoft Expression Encoder in LabVIEW
I am trying to use the Mircosoft Expression Encoder in LabVIEW, Mircosoft support the SDK, it can be download from http://www.microsoft.com/downloads/en/details.aspx?FamilyID=5c3c5f97-678c-4c99-a7fc-f84f320c626f
I google this topic, it seems some one has done this and put a LabVIEW 2009 VI in LAVA, see my attachment.
The problem is I cannot use the dll in LabVIEW, it give me "The selected file is not a .NET assembly, type library or automation executable." I don't know is the dll's problem or LabVIEW problem.
(2,835 Views)
The problem is that this is a .NET 4.0 assembly. LabVIEW only supports .NET 3.5 assemblies. I am not familiar with this component, but you might check to see if there is some earlier or alternative version built for .NET 3.5.
Jarrod S.
(2,822 Views)
