Mismatch between the DAQ assistant Rate and the output waveform dt
I am using an NI 9239 to acquire analogue input data. Using the DAQ Assistant I set acquisition mode N Samples, 8k samples to read and 8k acquisition rate. I wire the data output from the DAQ Assistant directly to a waveform indicator.
I expect the dt for the waveform to be 0.000125. I get 0.000120, which is an acquisition rate of 8333.333Hz!
What am I doing wrong?
Thank you.
(2,459 Views)
Accepted by topic author jiopaley
You have to read the specifications of the 9239 to answer your question. Focus on page 18/19.
Additional hint:
You specify the MINIMUM sample rate for the acquisition in the DAQ Assistant.
hope this helps,
Norbert
Norbert
Expert: Geometry
(2,454 Views)
thanks!
(2,447 Views)
