10-22-2019 05:36 AM
@altenbach wrote:
To wire two arrays (one for x, one for y) to an xy graph, all you need is wire the two arrays to "RE/IM to complex" (or similar) and wire the resulting complex array to the terminal of the xy graph and the rest will fall into place.
The easiest solution I found was to just use the bundle function. If someone else is having this issue create your x and y arrays in the front panel. Then create the xy graph from controls/modern/graph/XY graph then go into your block diagram and select "cluster class and variant"/bundle then on the left side connect your x array to the top of the bundle and your y away to the bottom. Then connect the right side of the bundle to your graph and you're done. Here's an example
To put two lines on the same graph you can use the build array function which is located in Programming/Array/Build Array
Here's an example
10-22-2019 05:47 AM
10-22-2019 07:53 AM
@Bob_Schor wrote:
As a "Reality Check", I also tried dropping an Express Graph (ooh, I really dislike Express VIs) on my Windows 10 (x64)/LabVIEW 2019.0f2 (32-bit) system. Block Diagram looks fine to me (see below for Snippet).
Ex XY Graph
Bob Schor
Just in case you are not familiar with LabVIEW snippets (the above, and its attached version, were clearly identified as such), this is a "feature" NI introduced 5-6 years ago in the Edit menu that allows you to save a VI as a PNG, and saves enough additional information that if you drag and drop this PNG onto a Block Diagram, it automagically becomes a VI.
I no longer have the original VI, but I dragged and dropped the attachment "2019 Express Graph.png" onto a blank LabVIEW 2019 Block Diagram and am attaching the saved VI.
Bob Schor
10-22-2019 08:02 AM
Just to be clear, the "build xy graph" express VI is not recommended here, because you have two arrays, not two dynamic data sets. Converting arrays first to dynamic data, the piping them through a NOOP express VI makes me cringe. Most likely it was originally there because whoever wrote the program did not know what they were doing.
(This express VI has one optional feature to "retain data between calls" so it can act more like an xy chart if you set that option, but eventually you'll run out of memory if you use it incorrectly this way)
10-22-2019 08:41 AM - edited 10-22-2019 08:42 AM
I do believe there is something wrong with benm92's LV 2019 installation as well as mine. Is that EX XY Graph in the Graphs palette of the Front Panel a Merge VI?
When I open Bob's VI in 2019, it looks good. When I go to the front panel, right click, Graphs, EX XY Graph and drop it on the front panel, the VI breaks and looks like this.
10-22-2019 09:18 AM
Essentially, yes. You can put a VI on the controls palette and it will drop the contents (aka to the seasoned individuals as a Merge VI).
10-22-2019 10:01 AM - edited 10-22-2019 10:06 AM
for me the same problem:
The error message is what I got for double-clicking the (missing) ExpressVI.
(But well, I noticed this problem only because of this thread…)
Addition: This is found in the vi.lib:
So apparently the ExpressVI functions are present…
10-22-2019 10:05 AM
10-22-2019 10:07 AM
10-22-2019 10:25 AM
@cbutcher wrote:
Well, I have exactly the same symptoms and experience as GerdW with this - despite using LabVIEW 2019 nearly every day since NI Week, this is the first time I've seen this 🙂
I guess the question becomes... Hey Bob, how did you install LabVIEW? We all did it wrong 😞 😉
It works just fine for me. I just did a normal install. At least, I don't think I used any magic sauce. Did you install the latest patch through NIPM? I have the f2 patch installed. It does not appear to be available through a simple download and install.
