Missing AI Temp TC
I do not have the AI Temp TC for the create channel vi.  How do I get this back.  I tried repairing my driver, but it didn't fix the problem.  What else can I do?  Rob F. you helped me before what do you hink the problem is now?  Thank you so much!
        Kenny
(3,218 Views)
 I apologize for the duplications.  I am new to this and I'm just trying to figure out how to use this system.  I am a research assistant at a University and have no engineering background.  I am just trying to figure out what these professors want and deliver.  I apologize again for any inconvenience.  I tried to find where I could delete the duplicate messages, but couldn't.  Tell me how and I will delete them.  Thanks.
Kenny
(3,186 Views)
Explain exactly what you mean. If you right click on the Create Channel and do a select type, are you unable to do an Analog Input>Temperature>Thermocouple?
The VI you posted in one of your duplicate threads does not make any sense. You have 5 physical channel controls. There is no way that you could have hooked those up to an unmodified Create Channel function and there would be no reason at all to modify it. DO NOT modify any of the VIs that are part of the LabVIEW distribution. Attached is an 8.2 version of the DAQmx Create Channel (AI-Temperature-Thermocouple).vi. You should open this and save it to vi.lib>DAQmx>Create>Channels.llb. If that does not work, try uninstalling DAQmx, and LabVIEW and then do a fresh install.
(3,186 Views)
Correct.  If I click on Create Channel It doesn't have the option to select thermocouple, it just has RTD and thermistor.  Thank you so much I will try your advice.  Thanks you greatly for your help.
Kenny
(3,180 Views)
