Missing DAQ Assistant in LabView 8.0
In LabView 7.1 I have the DAQ Assistant under the "Inputs" folder, but in ver 8.0 it is missing.
However I do have some DAQ functions in the "Measurement I/O" folder, but not the DAQ Assistant.
I have installed the PCI 6601 that I want to use as position controller and general I/O
any suggestions?
thanks,
gert
(3,335 Views)
gert,
What version of the DAQmx driver are you using? It sounds like you have not installed support for LV 8.0 when you installed the driver. I would recommend trying to reinstall the lastest version of the DAQmx driver.
Abhinav T.
Abhinav T.
Applications Engineering
National Instruments India
LabVIEW Introduction Course - Six Hours
Getting Started with NI-DAQmx
Measurement Fundamentals
(3,316 Views)
Abhinav,
I reinstalled the drivers that came with the PCI 6601, and everything works fine.
It seems that Labview 8 has to be installed before the drivers.
thanks for your help
gert
(3,305 Views)
