Missing DAQ Assistant
Hello!
After installing LV8.5.1, I found out that the Daq Assistant is not showing in the express pallete.
Any ideas?
Thanks!
______________
KowdTek
LabVIEW 2009
One Step At A Time, Maybe Two...
(4,243 Views)
Did you install the device drivers CD/DVD after installing LV 8.5?
(4,219 Views)
I had to reinstall everything and it's now working.
Thanks!
______________
KowdTek
LabVIEW 2009
(4,208 Views)
I have this exact same problem. Despite all my attempts at repairing, re-downloading, etc., no success.
(2,975 Views)
I have this exact problem. I followed everything on this thread and still have trouble.
(2,987 Views)
What version of LabVIEW and DAQmx?  Are you just missing the Assistant 😝 and have NI DAQmx palette in the Measurement I/O Functions with DAQmx VIs in it, or is everything missing?
Did you check NI-MAX Software section to see if you have a version of DAQmx installed that's compatible with your LabVIEW version??
Did you install DAQmx AFTER you installed LabVIEW???
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(2,964 Views)
I made an error. I have version 20.0 for LabVIEW and when I selected the DAQmx version off the NI site, I selected version 20.1. So, I uninstalled/reinstalled. All good now!
(2,938 Views)
