Missing NI-DAQmx Application Development Support 18.6 in installer
I have encountered a problem with older application in builds. There is a build of the installer which had selected NI-DAQmx Application Development Support 18.6 as an additional installer but due to installation of newer version Labview (2019 SP1, 2020) this selection is now in red (removed or upgraded product). Other additional installers were found but only this one was is missing. Is this intentional?
I couldn't find any info about this so I am not sure if it's a problem that could be fixed. I am not the original creator of this build so I am not exactly sure why is there even Development Support as it is for the deployment of software. The only reference that I found told that in DAQmx installer there should be selected Development Support due some unspecified reasons.
Message 1 of 1
(2,089 Views)
