Missing NI Module RoboRIO support for 2017
The first time I installed Labview and the myRIO toolkit stuff, it worked fine. Then, later it keeps saying it is missing modules. I have tried uninstalling everything and reinstalling many times in slightly different ways and updating everything in slightly different ways in case I was getting the order wrong.
Currently I am trying to connect myRIO to Labview 2017. I have installed everything - including FPGA, real-time, robotics module. It says the roboRIO module support is missing and this is referenced the myRIO main.vi (when I try to open a blank myRIO project) as well as a subVI (Error Cluster from Error Code). It then also says there is a Dependency Loaded from New Path warnings from that subVI. From what I can tell from copious amounts of research trying to understand all the different parts and updates to Labview, roboRIO is not current for the 2017 versions, so why is it being reference in the main.vi of the 2017 version?
(3,896 Views)
        Please, try to install 'NI LabVIEW 2017 myRIO Software Bundle DVD 1' and 'NI LabVIEW 2017 myRIO Software Bundle DVD 2' and run them on your computer, you can find them on the following NI webpages:
http://www.ni.com/download/ni-myrio-software-2017/6596/en/
http://www.ni.com/download/ni-myrio-software-2017/6597/en/
        I got the same problem, then I used the 'Web-Based Installer LabVIEW myRIO Software Bundle 2017' to install all the modules in the installation wizard, and it worked for me, you can find it on the following NI webpage:
http://www.ni.com/download/ni-myrio-software-2017/6598/en/
All the best,
Hani.
(3,687 Views)
