Missing Sound Output VIs
Hi Slowpoke,
I was able to load the DLL successfully using this syntax:
#include <userint.h>
#include "Noise Tool.h"
#include "windows.h"
typedef void (*MYPROC)(LPTSTR);
int main ()  {
    MYPROC ProcAdd;
     HINSTANCE hinstLib;
     int fFreeResult, fRunTimeLinkSuccess;
    hinstLib = LoadLibrary("Noise Tool.dll");
    ProcAdd = (MYPROC) GetProcAddress(hinstLib, "Test123");
    if (fRunTimeLinkSuccess = (ProcAdd != NULL))
            (ProcAdd) ("message via DLL function\n");
    FreeLibrary(hinstLib);
return 0;
Can you successfully load the library using this code?
Also, it appears lvsound2.llb is not being linked properly when you build the DLL. What happens if you include C:\Program Files\National Instruments\LabVIEW 8.2\vi.lib\sound2\lvsound2.llb as a support file?
Cheers.
| Michael K | Project Manager | LabVIEW R&D | National Instruments |
Message 11 of 26
(2,304 Views)
SHOULD SAY
ProcAdd = (MYPROC) GetProcAddress(hinstLib, "PlaySound");
Now who's the Slowpoke? Smiley Wink
Message 12 of 26
(2,299 Views)
Hi Michael,
I was unable to successfully load the DLL using the code you posted.  (Perhaps I'm misplacing it within my application...)
When I include "lvsound.llb" as a support file, I get the following error message:  "The build was unsuccessful.  Possible reasons: Polymorphic VIs cannot be used as Startup/Exported or Dynamic VIs for applications or shared libraries."  Then it gives a file path ending in "lvsound.llb\__ArrWfmsToData.vi".
Additionally, I tried to make an executable out of a VI that successfully called my DLL in LabVIEW, but got the same errors as in my LabWindows program when I tried to run it.  That would seem to confirm that the fault lies with the Application Builder.  What do you think?
Thank you for your time and your patience!
Slowpoke
Slowpoke
CLAD (believe it or not!), using LabVIEW 8.5
They don't call me "Slowpoke" for nothin'!
Message 13 of 26
(2,295 Views)
Ah.  That might explain things...  Smiley Happy  I'll try again.
Slowpoke
Slowpoke
Message 14 of 26
(2,294 Views)
Hi Michael,
I tried your sample code again and got a linking error: "Failed to open external module."  The VI error described previously remains unfixed.
Slowpoke
Slowpoke
Message 15 of 26
(2,283 Views)
Hi Slowpoke,
Let's move back to LabVIEW for a bit, as my inability to reproduce your problem has made me more cautious. Here are some questions to help troubleshoot the LabVIEW DLL build:
1. Have you modified the paths in the sound VIs? Have you moved the sound VI from their default location in vi.lib?
2. Is lvsound2.dll included in your library build?
3. At what point does calling the DLL fail when you build a debuggable DLL (Advanced >> Enable debugging)?
Cheers.
Message 16 of 26
(2,275 Views)
Hi Michael,
1.  No.  The sound VIs are in vi.lib.
2.  Yes.
3.  I'm not sure I'm even able to create a debuggable DLL.  I checked the "enable debugging" option in the app builder (as well as the "wait for debugger on launch" option), but the call fails just as it did before, except the error message has changed to "The VI is not executable.  The full development version of LabVIEW is required to fix the errors."
This whole situation is, as Tolkien might say, passing strange.  Might an unistall and reinstall of LabVIEW solve the problem?
Slowpoke
Slowpoke
Message 17 of 26
(2,264 Views)
Hi Michael,
Please disregard the comments under (3.).  I find it helps if I take time to learn how to do things, such as debug a running executable, before posting.  Smiley Tongue
The DLL fails when I step into the Call Library Function node on the LabVIEW calling VI.  Everything else is as described.
Sorry 'bout that...
Slowpoke
Slowpoke
Message 18 of 26
(2,258 Views)
Hi Slowpoke,
With this information we can confirm linking to lvsound2.dll as the definitive problem. We now must determine why lvsound2.dll is being linked to incorrectly.
When you probe the file path (or reference) going into the Call Library Function node, what is the exact path?
Cheers.
Message 19 of 26
(2,249 Views)
Hi Michael,
Hope you had a good weekend!  I use the file path selector under "Configure..." (the DLL fails if I select the "Specify path on diagram" option).  The exact file path is:
C:\Documents and Settings\Administrator\My Documents\Projects\LabView Projects\builds\Noise Tool\Noise Tool DLL\Noise Tool.dll
Slowpoke
Slowpoke
Message 20 of 26
(2,236 Views)
