Missing axis features under Default 7350 settings under NI Motion Devices in MAX
I'm trying to setup a stepper motor configuration using MAX and when I expand the "Default 7350 Settings" tree all I get is Axis 1 - Axis 4...but the real problem is that I dont have all the option trees that are suppose to be listed under each Axis, such as Axis Configuration, Motion I/O settings, Trajectory Settings, etc. I'm not sure if I'm missing some type of configuration file or driver has problems...any suggestion would be greatly appreciated.
Terry
(2,800 Views)
Hi TC,
Plase post a screenshot of what you are seeing/not seeing. Also, please post a list of what software you have installed?.
Joshua B.
(2,778 Views)
