Missing browser plug-ins
I have LabVIEW 2011 installed in my PC and the labview program runs on it while communication with hardware via c-RIO. I have Mozilla browser plugins installed for LabVIEW Run-Time 2011. When I try to reinstall LabVIEW plug-ins, it says a higher version is already installed. When i try to run the same program on a web browser as html, it says plug-in missing. What are the possible solutions for this?
(3,268 Views)
Not really sure if you still really need help in this but did you install any LabVIEW plugins that is of higher version than the one you are installing? What is the Modzilla browser plugins that you are trying to install? Have you tried using IE instead?
Lennard.C
Learning new things everyday...
(3,128 Views)
