Missing connection between Labview and my QuantumX 840B
Hello there,
I need to analyze my incoming data from the HBM QuantumX 840B in Labview but there is an issue with the incoming signal. I tried the software from HBM itself and it worked so there must be an issue with the driver or maybe an age difference between the Labview version and the driver version.Normally you should be able to see the icons of HBM under user controls but the folders are empty. There are no VIs which could be selected.
While running the "QuantumXProgramControlledDemo.vi" we got the Error 1172 which says there occured a property Node. It says the key can´t be zero.
I am using Labview 19 Sp 01 and my QuantumX is running on the version 4.0.34.
Maybe some of you had the same problem and can help me.
Kind regards
Niklas
(1,268 Views)
Are you using the HBM LabVIEW Driver?  Can you contact HBM and ensure the Driver is compatible with your version of LabVIEW?  Perhaps you need a newer (or older) HBM driver ...
Bob Schor
(1,210 Views)
Hi Nicklas,
did you manage to fix it?
I am struggling myself to get connected to MX440b through Labview and others but not with CATMAN.
Maybe you can give some tips on this for me.
Måske er du endda dansk?
(1,150 Views)
