Missing most of NI Vision Acquisition (Image Acquisition)
I am trying to open a code which works with a PCI-1410 frame grabber. I know the code is working on another computer but when I open it looks for these .vi files:
IMAQ Copy Acquired Buffer.vi
IMAQ init.vi
IMAQ Configuer List.vi
IMAQ Configuer Buffer.vi
IMAQ Start.vi
IMAQ Close.vi
I know all of them are in "NI-IMAQ Palette" <http://digital.ni.com/public.nsf/allkb/392E8F10F049918986256A3B005D484A> and I have installed NI-IMAQ 3.1 on my computer but still can't find the those vi.
I have "NI Vision Development Module" <http://www.ni.com/vision/vdm.htm> which has NI Vision Aquisition included.
I also uninstalled the labview and installed "Labview 2009" & "Vision Development Module" & "NI IMAQ 313". but still when I open my code it looks for those VIs.
Where can I find them or how can I fix this problem?
Best Regards
(3,557 Views)
Accepted by topic author NFarr
Hey Navid,
This is Alex from National Instruments. The version of IMAQ specified is not compatible with LV 2009 and I believe this is why you are not able to access the functions. Check the following link for a compatibillity chart for the IMAQ/IMAQdx drivers:
Compatibility Chart
I would recommend you install the latest version of NI Vision Acquisition Software which comes with the latest IMAQ 4.5 that is compatible with LV 2009.
Vision Acquistion Software
A. Z'Atari
(3,537 Views)
For my project, i need to implement the following steps:
Please can any ine help. very urgent
step 1: select ROI of apple image.
step2: Image to HSI conversi
step3: Take hue component from HSI image
ste4: then hue histogram
i attached some code here.
(3,266 Views)
I saw you also posted this in its own thread.  Use that post because more people in the community will see it since this post was solved over a year ago.
I would suggest you start with some of the examples in the LabVIEW example finder.  Open Toolkits and Modules»Vision.  There are several examples under Applications and Functions.
Greg H.
(3,253 Views)
   Thax. i have used Ni vision assistance. But i am getting some problem. Can you give me some tips.
Thank you
(3,250 Views)
