Missing "Compare VIs" menu item
According to the Help, it must be there
"Select Tools»Compare»Compare VIs from the front panel or block diagram menu of a VI"
But it is not (see the screenshot attached).
Using LabVIEW Full Development System 2011 SP1
Why?
Message 1 of 8
(3,467 Views)
Compare VIs requires the professional system. Full is not enough.
Quote from this page :
"Note  The Compare VIs dialog box is available only in the LabVIEW Professional Development System."
Compare features here.
Message 2 of 8
(3,463 Views)
thank you
Message 3 of 8
(3,449 Views)
That being said, I think a case could be made to include this core functionality in all levels of LabVIEW.
For a text programming language, anyone can do a diff on two text files. It is a very basic functionality.
The usability of LabVIEW as a full featured programming language is crippled if code comparison is not part of the basic tool set. Maybe I'll write it up as in idea.....
Message 4 of 8
(3,448 Views)
Quote from this page:
Sadly, with a software lease the full development is automatically activated.
Activating the pro isn't a problem, but you have to do it.
And when renewing, the professional license seems to fall back to full.
Message 5 of 8
(2,306 Views)
I have the same problem but I have installed the professional development system.
Can anyone help me?
My LV Version is 21.0.1 Professional Development System
Attached is a screenshot of my Tools menu.
Thank you all
Message 6 of 8
(48 Views)
Compare appears only after you open a project or even a simple vi.
Paolo
Message 7 of 8
(40 Views)
Thank you Paolo, that´s it.
Message 8 of 8
(30 Views)
