Missing run stop button both front panel & diagram
I have a VI a colleague gave me and one of it's subVI is missing all the buttons.
It is not the usual trick of custom window appearance, there are no buttons even in the diagram, and in properties, I'm not allowed to check the box to display them. (see snapshot attached)
As you can see, in Execute menu, I can't either run or stop (sorry the interface is in French) , but I can go to execution mode, or execute step by step, and the subVI runs normally.
Anyone ever seen such a weird thing ?
For info, I'm using Labview2012 and the VI is from Labview2010 and it's not protected.
(2,957 Views)
Instead of an image that many of us cannot read, attach the actual VI.
(2,949 Views)
Accepted by topic author Sebh
I am guessing that the priority (VI Properties -> Execution) has been set to subroutine.
(2,944 Views)
Well seen Darin.K , never knew it was having this effect.
(2,920 Views)
