Missing subVI
I am working on a project in LabVIEW 2013 where in of the cases of case structure, missing SubVI icon is coming though that SUbVI exists in the project.
Now neither I am able to delete that SubVI instance nor I am able to replace it with other SubVIs. If I try to replace it with some other function, that function is placed over this SubVI instance.
I am getting this error too while saving the project.
LabVIEW Save Error code5: BD heap.
Does Anyone have idea about these issues?
(2,941 Views)
Hi Kriti,
I am working on a project in LabVIEW 2013 where in of the cases of case structure, missing SubVI icon is coming though that SUbVI exists in the project. Now neither I am able to delete that SubVI instance nor I am able to replace it with other SubVIs.
Get an older (but working) version of your project from your SCC system (or backup).
Problem solved…
I am getting this error too while saving the project. LabVIEW Save Error code5: BD heap.
Open that VI. Copy all the BD content and paste it into a new VI.
Then save the new VI…
(2,912 Views)
Hi GerdW,
I have already tried to replace it with new VI but still getting the same issue, not able to delete missing VI.
@GerdW wrote:
Hi Kriti,
Problem solved…
(2,877 Views)
