Missing subvi DAQmx Read.vi/LabVIEW load error code 21: An external subroutine required for execution could not be found.
I have a Program that uses GPIB & PCI-6229 DAQ board to communcate with signal generators. To make a standalone .exe , I
1- Built a .exe and installer using the Tools > Built Applications...
2- Installed NI-DAQmx Version 7.1 for XP
    (nidaq710.zip (NI-DAQ Installation File (537MB)))
3- Installed  NI-VISA Version 3.3.1 ( visa331full.exe (95.3 MB))
AND YET! when I try running my program on a different machine I get the following ERROR:
"Missing subvi DAQmx Read.vi ...
LabVIEW load error code 21: An external subroutine required for execution could not be found"
How should I fix this?
-A
Message 1 of 13
(13,405 Views)
Hi Aida,
Did you install the LabVIEW runtime engine on the deployment machine?
To run stand alone applications on a machine you need to have this piece of software installed. It's a free download and you can take it from the following site:
http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BBB002C1065?opendocument&node=132060_US
Regards
Sarah
Applications Engineer | National Instruments | UK & Ireland
Message 2 of 13
(13,396 Views)
Hi Sarah,
When I created my executable, I chose to create the installer at the same time (installer settings tab in the application builder). In this case, is the runtime engine included automatically with the installer (setup.exe) when deployed on the target machines ?
Thanks for the information,
Aida.
Message 3 of 13
(13,387 Views)
Hi Aida,
That is correct, it should be included automatically.
Could you post a list of all the NI Software and versions that is installed on your deployment system? Go to the Control Panel >> Add/Remove Programs >>NI Software.
Where did you get the nidaq710.zip file? was is from our website? if so could you post the link please?
Sarah
Message 4 of 13
(13,377 Views)
Hi Sarah,
thanks for your reply...I got the DAQmx driver from the following link
http://digital.ni.com/softlib.nsf/websearch/C1F802E457EA042586256DD00001B0C9?opendocument&node=132070_US
option: NI-DAQmx Version 7.1 for Windows 2000/98/ME/NT/XP NI-DAQmx Version 7.1 for Windows 2000/98/ME/NT/XP
**Does this version support NI PCI-6229 (M-series)?
thanks,
-A
Message 5 of 13
(13,372 Views)
oh, I forgot to answer the other question: The programs installed under NI Sw are:
DataSocket
IVI
NI-DAQ
NI-SWITCH
Session Manager
VISA
MAX
NI Spy
ServerExplorer
Message 6 of 13
(13,368 Views)
Hi Aida,
The error code you getting does appear to indicate the DAQmx driver isn't installed correctly.
Is the driver you're installing on the deployment system the same as the one you developed the code on? Did you have any problems when you had your application running before you built it? If you build the application into an executable will it run on the development machine?
Try installing a newer version of the driver and see if that helps.
The newest version is 8.1.
Install it on your development machine first and rebuild your application before installing it on your deployment machine so the versions correlate.
Let me know how you get on.
Sarah
Message 7 of 13
(13,367 Views)
Hi Sarah,
to answer your questions:
1- the executable does run on the development machine and I had no problem with my application running.
2- I am using the exact same versions on both machines.
I am a little hesitant with installing the new drivers version on the development machine. I am using Labview 7.1, won't updating the drivers to 8.1 cause compatibility issue for me?!
also, as i said before, I am using a PCI6229 board. M series. Is this board supported in version 7.1 that I downloaded?
thanks,
A
Message 8 of 13
(13,353 Views)
Hi Aida,
Your M series board is supported in DAQmx 7.3 and later. DAQmx 7.1 will not recognize the board which could be why you are running into problems. I agree with Sarah: you should upgrade to the latest version of the DAQmx driver on both machines and rebuild the executable. The latest DAQmx driver has support for LabVIEW 7.1, so that will not be a problem either and you shouldn't run into any compatibility issues. Hope this helps.
Hal L.
Message 9 of 13
(13,343 Views)
Hal and Sarah
Can you please also help on a problem presented at the thread
The problem is not solved so far.
Thanks.
Ian
Message 10 of 13
(13,276 Views)
