Mistakenly deleted "Timeout" case from Event Structure - How can I put it back?
I mistakenly deleted the "Timeout" case and then realized there was no other way to control the "idle state" of my program when it first starts.
How do I put it back?
Is it sufficient to create a blank case with a constant wired to the Timeout value?
Is there some way to name that case "Timeout"?
(6,305 Views)
Accepted by topic author wildcatherder
Look under <Application> in Event Sources.
(6,301 Views)
Thanks for the quick solution.  It's one of those dumbass things that only a few people will ever do.
(6,297 Views)
I'll bet it happens a lot more often than you think.  It is not that hard to select Edit when you mean to Add an Event Case.
(6,293 Views)
