Mixed Data Logging,
For some reason my potentiostat program stops at random time intervals and then starts up again without popping up as an error. However, it switches the values while the experiment is running.
For example, the first test shown in this document shows the experiment stopping at 51 minutes and then resumes at 51.5 minutes but instead of potential to current to current exponent to ph, it executes potential twice and seems to mess up the order completely.
We think it may be a buffer problem within the flat sequence structure but are not sure how to fix this. We put probes after each read/error out and there aren't any errors but reads our data in the wrong places, for instance VDATA would suddenly read the data of pHData and CDATA would read VData.
If anyone can help us out that would be great! thanks!
(3,520 Views)
Duplicate post
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,510 Views)
I'm not sure why the read buffers mix up their outputs, has anyone had an encounter with this??
(3,501 Views)
jabano, this is a duplicate of your other post, in which people are trying already to help. Post the essentially the same question, or variations of the same question, in multiple posts does not result in faster answers to any part of your questions. Please try staying in one thread, the people concentrating on that one may never see this one, and vice versa. You can ask additional, seemingly unrelated, questions in the initial thread. This one seems to be about the same initial problem.
Putnam
LabVIEW Champion
(3,483 Views)
