Mixed Signal Graph Legend Plot Name and Graph Area Y Scale Name hidden
I have a customized mixed signal plot grpah and it when the plot names are written to it, it autosizes things and they are in chaos with overlapping text.  Is there a way to fix this?  I am also expereincing several labview crashes...
(2,635 Views)
Hi id,
i am having the same problem,
if you were able to fix it, can you please share your fixing method.
appreciate it
(2,530 Views)
You may be able to fix it with the YScale.Position property node
(2,521 Views)
