Mixed Signal Graph does not update Plot Area correctly
When I set the Plot Area Bounds for my mixed signal graph in LV 8.2.1 I get inconsistent results. I have two VIs -- VI Works.vi does what I expect (it sets the bounds of the plot to the proper size as far as I can tell). I have another VI (VI Errors) which has the same code but does not work. To me, this seems like a bug. Let me know if there is anything that can be found/fixed/worked around for this. Thanks in advance.
(2,795 Views)
They seem to be correct to me. The reason why you're getting a different result in VI Errors1.vi is because the position of the plot is different. If you set the position of the plot to be the same as VI Works1.vi, then the results will be the same. Perhaps you want to use Plot Area:Size:Height instead of Plot Area Bounds.
Stanley Hu
Applications Engineering
http://www.ni.com/support
(2,776 Views)
