Mixed Signal Graph dynamic Data Type
I am trying to implement a Digital Signal and a Analog Signal. To show them together I use the Mixed Signal Graph. The digital signals I use are boolean arrays. I use the boolean-array to dynamic data function and use the bundle method to cluster also the dynamic data element and the analog signal with type integer 16 arrays. The analog signal is shown correctly but the digital graph is empty. If I show the input dynamic data in a graph indicator the signal is displayed in the graph. Attached is a screenshot of my used cluster.
Have I forgotten some settings in my Mixed Signal Graph?
Thanks for your help.
Kind Regards,
Joachim
(2,804 Views)
Sorry for the posting. I've solved my problem. I have to enable the Ignore Time Stamp in the context menu of the digital graph.
Kind Regards,
Joachim
(2,800 Views)
