Mixed Signal Graph plot area shrinked, after scale visible property set
If you toggle the property "Y Scale visible", the plot area gets shrinked every time the Y scale is set to visible.
I didn't find a way to clean up the MSG again after it's "messed" up.
Press the button "Visible" several times in the attached vi "Mixed signal graph error" and you see what I mean.
Has anybody an idea how to get the Mixed signal graph to display the plot areas int the correct size again?
Berni
(2,784 Views)
Hello Berni,
the problem is that each time when the y-axis is visible the relative position is changed to the point of the displayed y-axis.
The solution is to set the position manually.
mfg
Stefan
Message Edited by Hemetsberger on 08-03-2007 03:54 AM
Message Edited by Hemetsberger on 08-03-2007 03:55 AM
(2,773 Views)
