12-24-2022 09:21 AM
Hope you all doing well.
I am trying to plot graph of 5 values together, but the y scale is automatically getting reversed is there a way to correct this.
Thanks and Regards
Solved! Go to Solution.
12-24-2022 09:34 AM
Solved the problem ,I was initially using activeplot property but then , I changed to ActyScl and marked all as write.
Don't know the reason but it works now.
12-24-2022 03:24 PM - edited 12-25-2022 10:23 AM
You don't really need any property nodes. Just edit one of the end marker to have the value of the other side and the scale will flip. For example if you click on the 30 of the upper scale and enter zero, the top marker will change to 30. (You can also change it in the properties).
