Mixed signals DAQ assist will not split
I'm using the split signals on a NI 6363-USB split the signal to be fed into different function in the labview code.
The DAQ assist is located within 1 while loop.
However it seems that rather than splitting the signal it seems to make 3 (same number of additional added channels) 'rough' copies of the signal.
Is this a common problem? Suggestions to fix this?
(3,263 Views)
Hi florian,
most probably this is just a programming error in your VI - but as you didn't attach your VI this guess may be wrong…
Check your VI. Twice.
Or even better: get rid of all ExpressVIs! (Seriously!)
(3,258 Views)
What other functions might be useful to replace the DAQ VI. We mainly are interested in reading in a signal and when certain values are reached (eg. we are filling a tank till certain pressure) creating triggering signals (TTL etc.) to open  valves, trigger camera.
(3,234 Views)
Hi florian,
you know how to create screenshots in Windows? Oh gosh, a photo taken with a phone…
But atleast one can read the comment in your blockdiagram: "Sensor1-USB6363-channel 0". I guess you read just this one channel with the DAQAssistent so the question is: how do you want to split this single signal into 4?
(It might help to learn LabVIEW basics. It definitely helps to use AutoCleanup!)
Thanks for those AppNotes from NI
(3,231 Views)
[video]
Create a snipette! Edit>>Create Snipette from selection.That eval version should have linked you to many training resources
(3,213 Views)
