Mixer measurements - LabVIEW
Hi All,
While working mixer measurements in LabVIEW using R&S vector network analyzer.
For a conversion loss usually VI's are not default available. So for measuring the Feedthru measurements, because of unavailable default VI(For Feedthru measurement) configured the VI's as follows,
1. Created a configuration of mixer settings using default config VI for mixer from R&S.
2. Imported wave-quantities VI's and measured the (b3/a1)@Port1 to check feedthru measurement.
Whether the above mentioned procedure really measures the mixer feedthru?
Thanks in advance for your guidance with response.
Message 1 of 1
(1,092 Views)
