Mobile module modbus I/O Server
Is it possible to establish a communiccation with modbus protocol between the PDA (master) and the slave device via WIFI connection?
I like to do this with configuring the I/O Server, not with the modbus library.
Zdenko.
(3,101 Views)
I am sorry to give you a negative answer to your question.
I have LabVIEW Mobile module 2009 and DSC  and a PDA target does not support I/O Server.
I have also installed modbus library, but some functions and proprieties under library's vi s are not supported under mobile target.
Probabily you could develop very low level code for mobile to implement modbus server, but it's very complicated.
Emil
(3,067 Views)
