ModBus/TCP
Hello!
We use Codesys to write data in the address range 0x3000...0x5fff to the non-volatile memory of the Wago 750-881 controller. There is a task to read this data from the controller's non-volatile memory using Labview. We have to read this data by ModBus/TCP.
Please tell me how to do this.
(3,684 Views)
Download the NI Modbus library from VI Package Manager.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,681 Views)
I would use the LabVIEW Modbus API. You can install it by the use of VI Package Manager.
(3,677 Views)
That is the same library I was suggesting.
Mark Yedinak
LabVIEW Champion
(3,671 Views)
Yes, you were quicker than me to type the answer and I discovered yours after sending mine.
(3,667 Views)
Ah, but you provided the link to the description. Kudos for that.
Mark Yedinak
LabVIEW Champion
(3,660 Views)
