T-Ray wrote:
> I have a 2 thread program (LV 6.1)that includes a user interface in
> thread 1 and a data acquistion loop in thread 2. When thread 2
> initiates data collection, it pops up a non-modal status bar. If this
> bar pops up at the same time that a user opens a new modal window, the
> modal window is either not displayed or falls behind other windows and
> is not visible or accessible. Hence the program locks up since the
> user cannot access or close the modal window. The only way to solve
> the problem is to kill the program with the WinXP TaskManager. Data
> collection is run with high priority while the user interface is run
> with normal priority. All user interface screens are run with wait
> for front panel activity. Is there a way to to k
eep the modal window
> on top or to restore it without crashing the program?
There is also a possible problem which seemed to have gotten introduced
in LabVIEW 6.0 or 6.1 and is afaikr fixed in 7. If you debug an
application once, the VIs ar all forced to be not modal (which is a very
good thing to not lock you out during single stepping and such). But for
some reasons this "force non-modal" operation stays enabled after that
for the entire rest of the LabVIEW session. Quiting LabVIEW and
restarting fixes that. It is only a small annoyance during debugging but
much prefarable to not being able to get at the diagram in which a
breakpoint requires your attention.
Rolf Kalbermatter
Rolf Kalbermatter
My Blog
