Modbus AOI
the test i'm doing is between STM32 board as master and LabVIEW as slave using modbus API library.
where STM32(master) request to read data from LabVIEW.
the hardware im using is "STM32 board", "RS485 to TTL converter", "USB RS485 converter"
i have worked with "SIMPLY MODBUS SLAVE" software as slave and "stm32" as master and i have attached the screenshot with it where you can see the the data in debug mode of stmcube ide given by the "simple modbus slave"simple_modbus_slave_screenshot.jpeg
i have given below stm32 code
/* USER CODE BEGIN Header */
  * @file           : main.c
  * @brief          : Main program body
  * @attention
  * Copyright (c) 2025 STMicroelectronics.
  * All rights reserved.
  * This software is licensed under terms that can be found in the LICENSE file
  * in the root directory of this software component.
  * If no LICENSE file comes with this software, it is provided AS-IS.
/* USER CODE END Header */
/* Includes ------------------------------------------------------------------*/
#include "main.h"
#include "modbus_crc.h"
/* Private includes ----------------------------------------------------------*/
/* USER CODE BEGIN Includes */
/* USER CODE END Includes */
/* Private typedef -----------------------------------------------------------*/
/* USER CODE BEGIN PTD */
/* USER CODE END PTD */
/* Private define ------------------------------------------------------------*/
/* USER CODE BEGIN PD */
/* USER CODE END PD */
/* Private macro -------------------------------------------------------------*/
/* USER CODE BEGIN PM */
/* USER CODE END PM */
/* Private variables ---------------------------------------------------------*/
UART_HandleTypeDef huart2;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_USART2_UART_Init(void);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* Private user code ---------------------------------------------------------*/
/* USER CODE BEGIN 0 */
uint8_t RxData[8];
uint8_t TxData[8];
int Data[16];
int indx = 0;
void HAL_UARTEx_RxEventCallback(UART_HandleTypeDef *huart, uint16_t Size)
void sendData (uint8_t *data)
HAL_GPIO_WritePin(TX_EN_GPIO_Port, TX_EN_Pin, GPIO_PIN_SET);
//HAL_Delay(100);
HAL_UART_Transmit(&huart2, data,8, 1000);
HAL_GPIO_WritePin(TX_EN_GPIO_Port,TX_EN_Pin , GPIO_PIN_RESET);
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval int
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration--------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  /* Configure the system clock */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  /* Initialize all configured peripherals */
  MX_GPIO_Init();
  MX_USART2_UART_Init();
  /* USER CODE BEGIN 2 */
  HAL_UARTEx_ReceiveToIdle_IT(&huart2, RxData, 32);
   TxData[0] = 0x05;  // slave address
   TxData[1] = 0x03;  // Force single coil
   TxData[2] = 0;  // coil address high
   TxData[3] = 0X04;  // coil address low
   //The coil address will be 00000000 00000000 = 0 + 1 = 1
   TxData[4] = 0;  // force data high
   TxData[5] = 0X05;  // force data low
  // uint8_t TxData[8] = {0x05, 0x05, 0x00, 0x00, 0xFF, 0x00, 0x00, 0x00};    // 8-byte buffer
   TxData[1] = 0x06;  // Preset single Register
   TxData[2] = 0;  // Register address high
   TxData[3] = 5;  // Register address low
   //The coil address will be 00000000 00000101 = 5 + 40001 = 40006
   TxData[4] = 0x12;  // Preset data high
   TxData[5] = 0x34;  // Preset data low
   TxData[1] = 0x0F;  // Force Multiple coils
   TxData[3] = 0;  // coil address low
   TxData[4] = 0;  // no. of coils high
   TxData[5] = 0x0F;  // no. of coils low
   // Total no. of coils = 00000000 00001111 = 15 coils
   TxData[6] = 2; // Byte count (15 coils would need 2 bytes)
   TxData[7] = 0x35;  // Data for first 8 coils
   TxData[8] = 0x74;  // Data for next 8 coils (actually 7 coils)
/*   TxData[1] = 0x10;  // Preset Multiple Registers
   TxData[3] = 0;  // Register address low
   //The coil address will be 00000000 00000000 = 0 + 40001 = 40001
   TxData[4] = 0;  // no. of Registers high
   TxData[5] = 0x03;  // no. of Registers low
   // Total no. of Registers = 00000000 00000011 = 3 Registers
   TxData[6] = 6; // Byte count (3 Registers would need 6 bytes (2 bytes per register))
   TxData[7] = 0x12;  // Data High for first Register
   TxData[8] = 0x34;  // Data low for first Register
   TxData[9] = 0x56;  // Data High for 2nd Register
   TxData[10] = 0x78;  // Data low for 2nd Register
   TxData[11] = 0xab;  // Data High for 3rd Register
   TxData[12] = 0xcd;  // Data low for 3rd Register  */
   uint16_t crc = crc16(TxData, 6);
   TxData[6] = crc&0xFF;   // CRC LOW
   TxData[7] = (crc>>8)&0xFF;  // CRC HIGH
   sendData(TxData);
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
    /* USER CODE END WHILE */
    /* USER CODE BEGIN 3 */
  /* USER CODE END 3 */
  * @brief System Clock Configuration
  * @retval None
  RCC_OscInitTypeDef RCC_OscInitStruct = {0};
  RCC_ClkInitTypeDef RCC_ClkInitStruct = {0};
  /** Configure the main internal regulator output voltage
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  /** Initializes the RCC Oscillators according to the specified parameters
  * in the RCC_OscInitTypeDef structure.
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
  RCC_OscInitStruct.HSEState = RCC_HSE_ON;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
  RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
  RCC_OscInitStruct.PLL.PLLM = 8;
  RCC_OscInitStruct.PLL.PLLN = 336;
  RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV2;
  RCC_OscInitStruct.PLL.PLLQ = 7;
  if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
    Error_Handler();
  /** Initializes the CPU, AHB and APB buses clocks
  RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
                              |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
  RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
  RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV4;
  RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV2;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_5) != HAL_OK)
    Error_Handler();
  * @brief USART2 Initialization Function
  * @param None
  * @retval None
  /* USER CODE BEGIN USART2_Init 0 */
  /* USER CODE END USART2_Init 0 */
  /* USER CODE BEGIN USART2_Init 1 */
  /* USER CODE END USART2_Init 1 */
  huart2.Instance = USART2;
  huart2.Init.BaudRate = 115200;
  huart2.Init.WordLength = UART_WORDLENGTH_9B;
  huart2.Init.StopBits = UART_STOPBITS_1;
  huart2.Init.Parity = UART_PARITY_EVEN;
  huart2.Init.Mode = UART_MODE_TX_RX;
  huart2.Init.HwFlowCtl = UART_HWCONTROL_NONE;
  huart2.Init.OverSampling = UART_OVERSAMPLING_16;
  if (HAL_UART_Init(&huart2) != HAL_OK)
    Error_Handler();
  /* USER CODE BEGIN USART2_Init 2 */
  /* USER CODE END USART2_Init 2 */
  * @brief GPIO Initialization Function
  * @param None
  * @retval None
  GPIO_InitTypeDef GPIO_InitStruct = {0};
/* USER CODE BEGIN MX_GPIO_Init_1 */
/* USER CODE END MX_GPIO_Init_1 */
  /* GPIO Ports Clock Enable */
  __HAL_RCC_GPIOC_CLK_ENABLE();
  __HAL_RCC_GPIOH_CLK_ENABLE();
  __HAL_RCC_GPIOA_CLK_ENABLE();
  /*Configure GPIO pin Output Level */
  HAL_GPIO_WritePin(TX_EN_GPIO_Port, TX_EN_Pin, GPIO_PIN_RESET);
  /*Configure GPIO pin : TX_EN_Pin */
  GPIO_InitStruct.Pin = TX_EN_Pin;
  GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
  GPIO_InitStruct.Pull = GPIO_NOPULL;
  GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW;
  HAL_GPIO_Init(TX_EN_GPIO_Port, &GPIO_InitStruct);
/* USER CODE BEGIN MX_GPIO_Init_2 */
/* USER CODE END MX_GPIO_Init_2 */
/* USER CODE BEGIN 4 */
/* USER CODE END 4 */
  * @brief  This function is executed in case of error occurrence.
  * @retval None
void Error_Handler(void)
  /* USER CODE BEGIN Error_Handler_Debug */
  /* User can add his own implementation to report the HAL error return state */
  __disable_irq();
  while (1)
  /* USER CODE END Error_Handler_Debug */
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t *file, uint32_t line)
  /* USER CODE BEGIN 6 */
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* USER CODE END 6 */
#endif /* USE_FULL_ASSERT */
this is the format to read data from LabVIEW:-
[11:34 am, 26/3/2025] Anurag Thorat: read data from slave code
[11:35 am, 26/3/2025] Anurag Thorat: 0x05; slave address
[11:35 am, 26/3/2025] Anurag Thorat: 0x03; command forb read data from register
[11:43 am, 26/3/2025] Anurag Thorat: message format for read data from slave
TxData[1] = 0x03; // Function code for Read Holding Registers
TxData[2] = 0; // register address high
TxData[3] = 0X04; // register address low
TxData[2] = 0;
TxData[3] = 0x04;
//The Register address will be 00000000 00000100 = 4 + 40001 = 40005
TxData[4] = 0;
TxData[5] = 0x05;
// no of registers to read will be 00000000 00000101 = 5 Registers = 10 Bytes
this is the LabVIEW block diagram screenshot and front panel screenshot, so please help me its not showing any error at labview side but stm32 doest show any data when we check in debug mode......modbus_block_diagram.png
(1,358 Views)
First problem I see is that your slave implementation opens a port, creates a Modbus slave then writes some registers and shutdowns the Modbus slave right again. It is highly unlikely that you can start that VI and the STM32 will be able to catch the Modbus slave for the very brief moment it is active before your VI shuts it down again. You need to have some loop in your LabVIEW VI that keeps the slave running before you eventually shut it down. Once the Shutdown VI executes, there is simply no slave present anymore that could answer your STM32 requests.
A Modbus slave needs to stay active and monitor the serial port in order to be useful at all. It is called slave in terms of Modbus, but is in reality the server side of things.
Rolf Kalbermatter  My Blog
(1,334 Views)
Thanks for your reply, I tried loop and it is working fine,
(1,314 Views)
It worked but now it is not working? for the same labview code...
(1,184 Views)
There are a zillion possible reasons for such behavior and many are rather hardware related than anything with LabVIEW. Since it is your setup, you really will have to do your own debugging. We can't it do for you.
(1,179 Views)
