Modbus ASCII
I'm a new user of Labview so I'm quiet lost. Smiley Embarassed
Someone know how to use the modbus library to communicate in ASCII mode with a machine ? An example will be welcome Smiley Happy
Peter.
Labview 2010
Message 1 of 8
(7,452 Views)
Hi Peter Saraiva,
                      There is a thread in Labview discussion forum related to this please check.
                      http://forums.ni.com/t5/LabVIEW/modbus-ASCII-library/td-p/641292
Thanks as kudos only:)
Message 2 of 8
(7,433 Views)
Hi Danil33,
thank you for your answer.
best regards
Peter.
Labview 2010
Message 3 of 8
(7,425 Views)
Peter,
             Do you achieved what you are trying to do?
Message 4 of 8
(7,422 Views)
no I don't, I've seen the link that you sent to me but there isn't the solution.
I found a VI which works in ASCII mode. The writing in my device works correctly but it lag when I have to read and a error occured : Timeout , but when I click on continue I can see the answer of the device in the box.
Any idea ?
i enclose the Vi
Peter.
Labview 2010
Message 5 of 8
(7,419 Views)
Hi Peter,
Thanks for your program!
Labview fails with their Modbus library. It doesn't work. Your program is much easier and (most important thing) it works fine.
The problem with your error is you read too many bits. You can solve this to change ''bytes to read'' in a property node with ''number of bytes at serial port''.
Feromartex
Labview 2010
Message 6 of 8
(7,312 Views)
It works for me.
In any case, you should note that this is an old thread, so presumably Peter no longer needs help with the problem.
___________________
Try to take over the world!
Message 7 of 8
(7,302 Views)
@tst wrote:
It works for me.
Haha I still want to thank Peter and I want to help other people.
Indeed the RTU works fine but the ASCII mode doesn't work to me.
Message 8 of 8
(7,283 Views)
