Modbus I/O server for LabVIEW and Touch panel - 2way communication
Hello every one,
Mansi here.
i want to do 2 way Wireless communication between Labview and Touch panel of Delta Electronics (DOPB03S211).  Attach the pic refer it. For that I came to know that i have to I/O servess and in that i have to use Modbus or Modbus RTU.
Now in my LV2010 i have only EPISC server. So how should i download the Modbus or modbus RTU server?????
And what is DSC and Real Time module? For this server and communication i have to download the DSC or Real time Module???
Please send me the link to download the above required things.
Plese hepl me out bcoz it stop my wrk, thanks in advance.Smiley Frustrated
(3,321 Views)
Your question asks about modbus communication to a touch panel but the image does not show any modbus connection to LabVIEW at all. The touch panel has RS-232 so if you need modbus to talk to the touch panel, I would suggest either installing DSC (extra cost option) or the LabVIEW modbus library.
(3,292 Views)
Dennis Thanks for reply,
Actually i have read that when you want communication at wireless network you should required the server for data transfer and for that this modbus rtu "PROTOCOL" is used. and i can use the modbus / modbus RTU/ modbus serial server. so what should i do to get the modbus server in my i/o server list?
And can you pl tell me what is DSC in detail? Because i m confused.Smiley Frustrated
(3,256 Views)
I'm sorry but I don't understand your setup. If you think you need modbus between the Zigbee modules, then you should be talking to Zigbee.
It is necessary when you say 'I have read', to provide a link.
(3,233 Views)
