Modbus IO Server Serial error
I am trying to write data on a Modbus slave using a Modbus master but when I run the master VI it gives me the following error. When I use the same com port for other serial communication it works but not for the IO server. I created modbus serial master using the IO server dmobus serial error.JPGialogue. Kindly help me out.
regards,
Mani
Message 1 of 1
(2,833 Views)
